Day 20: Edge Board DRV8825 Stepper Motor Driver
09/29/2023 at 17:40 • 0 commentsAn edge board with a DRV8825 stepper motor driver, limit switch connections and encoder inputs
source files can be found here: https://github.com/evezor/v0_stepper_driver_drv8825
This board uses the Evezor Stamp STMF405 MCU
Day 19: Edge Board 5up Digital Input Board
09/27/2023 at 22:05 • 0 commentsAn edge board containing five opto isolated inputs. All inputs are active HIGH. Each input comes with an input pin, a 5v and a gnd connection.
If I were to do this again, I would probably make a jumper that can switch between the 5v and whatever the bus voltage was.
source files can be found here: https://github.com/evezor/v0_5up_digital_input_boardThis board uses the Evezor Stamp STMF405 MCU
Day 18: Edge Board Stack Light
09/26/2023 at 17:53 • 0 commentsAn edge board containing 6 N-channel mosfets configured to operate a stacklight. Each mosfet also has a corresponding led for each channel.
source files can be found here: https://github.com/evezor/v0_stack_light_board
Day 17: Edge Board 4x Relay
09/25/2023 at 15:18 • 0 commentsAn edge board containing qty(4) 10 amp relays and qty(4) tactile buttons
source files can be found here: https://github.com/evezor/v0_4x_relay_board
Day 16: Edge Board Numberpad
09/25/2023 at 01:10 • 0 commentsAn edge board containing with a numberpad face with 12 buttons.
source files can be found here: https://github.com/evezor/v0_numberpad_board
Day 15: Edge Board Low Power Mosfet Board
09/23/2023 at 18:52 • 0 commentsAn edge board containing 3 low power mosfets capable of powering small loads like relays, small fans and LEDs. Also 3 buttons. Each output may be pulse width modulated. Power can come from the bus or external sources, selectable by jumper.
source files can be found here: https://github.com/evezor/v0_low_power_mosfet_board
Day 14: Edge Board Color Sensor Board
09/22/2023 at 18:07 • 0 commentsColor Sensor board with the VEML6040 chip for color detection with built in led for low light situations.
This also has mousebites on the sensor part of the board so it can be removed and the color sensor can be mounted closer and in a smaller form factor than the larger assembly.
source files can be found here: https://github.com/evezor/v0_color_sensor_board
Day 13: Edge Board Potentiometer Bar Graph
09/21/2023 at 13:46 • 0 commentsAn Edge boad with two buttons, two potentiometers and 2 multiplexed led bar graphs
Source files can be round here: https://github.com/evezor/v0_potentiometer_board/
Day 12: Edge Board Joypad
09/20/2023 at 11:50 • 0 commentsAn edge board shaped like a joypad. It has 2 analog inputs, 4 light up buttons, start and select pushbuttons, a dpad, a buzzer and a 5 position neopixel strip.
source files can be found here: https://github.com/evezor/v0_joypad
Day 11: Edge Board 7 Segment Display
09/19/2023 at 12:16 • 0 commentsAn edge board containing qty(2), 4 character 7 segment displays
source files can be found here: https://github.com/evezor/v0_7_segment_display_board
